OSERDESE2 documenation error?
UG471 says:
When DATA_RATE_TQ is set to DDR, the possible values for the TRISTATE_WIDTH attribute are 1 and 4
however table 3.8 only says only 4 as valid width
I would assume that when TRISTATE is not at all used, setting tristate width to 1 would also be valid, and not an error?
