Other FPGA Architecture resources
Other FPGA Architecture forum is the open platform to discuss about queries on Xilinx® Unified Architecture including Artix™-7, Kintex™-7, Spartan™-7, and Virtex®-7, Virtex® Family, Spartan® Family FPGAs and Zynq-7000 SoCs.
If you can’t find your answer in the below existing documentation, please  feel free to post your question on this Forum’s page.
User Guides :
UG474 :   7 Series FPGAs Configurable Logic Block
UG479 :  7 Series DSP48E1 Slice
UG472 :  7 Series FPGAs Clocking Resources
UG471:   7 Series FPGAs SelectIO Resources
UG480 :  7 Series FPGAs and Zynq-7000 SoC XADC Du al 12-Bit 1 MSPS Analog-to-Digital Converter
UG473 : 7 Series FPGAs Memory Resources
UG953 : Vivado Design Suite 7 Series FPGA and Zynq-7000 SoC Libraries Guide
UG384 :  Spartan-6 FPGA Configurable Logic Block
UG389 :  Spartan-6 FPGA DSP48A1 Slice
UG382 :  Spartan-6 FPGA Clocking Resources
UG381 : Spartan-6 FPGA SelectIO Resources
UG383 :  Spartan-6 FPGA Block RAM Resource
UG364 : Virtex-6 FPGA Configurable Logic Block
UG369 : Virtex-6 FPGA DSP48E1 Slice
UG362 :  Virtex-6 FPGA Clocking Resources
UG361 :  Virtex-6 FPGA SelectI O Resources
UG363 : Virtex-6 FPGA Memory Resources
IP Product Guides :
PG091 : XADC Wizard v3.3 LogiCORE IP Product Guide
PG070 : SelectIO Interface Wizard v5.1 LogiCORE IP Product Guide
Application notes :
XAPP888 :  Ultrascale and 7 series  MMCM and PLL Dynamic Configuration
XAPP524 :   7 series  Serial LVDS High Speed ADC interface
XAPP585  :  7 series  LVDS Source Synchronous 7:1 Serialization and Deserialization Using Clock Multiplication
