Observer tollinjose
P side of MRCC
I want to connect single ended clock to a MRCC pin in XC7v200T. Where to check a particular pin is positive or negative?
Re: P side of MRCC
Hi @tollinjose
The naming convention on the pins should tell you.
It follows this pattern
IO_LXXY_ZZZ_#
IO indicates it is a user IO
L tells you it is part of a pair.
XX will be a number to indicate which pair in the bank it is.
Y will indicate either P or N side of the pair.
ZZZ is usually for some special function
# tells you the bank number.
For example:
IO_L13P_T2_MRCC_34
is a user IO that is the part of the 13th pair in bank it is also in memory byte group 2, and it is a multi region CCIO.
The number indicates it is located in bank 34.
You could also open the IO pin planning view post synthesis and lock the single ended clock to the P-side of any MRCC clock pair in the desired bank
Observer tollinjose
Re: P side of MRCC
Thank you @klumsde for quick response. But I am not familiar with this naming. What i know is some thing like v42 or b32. Is there a document to correlate same ?
Re: P side of MRCC
there is a packaging and pinout guide.
http://www.xilinx.com/support/documentation/user_guides/ug475_7Series_Pkg_Pinout.pdf
you can use table 2-4 to download the ASCII pinout file.
for example
https://www.xilinx.com/support/packagefiles/v7packages/xc7v2000tflg1925pkg.txt
