mwerner2000
PCIe and Additional USer Logic with GTPs in one Quad
Dear Ladies and Gentlemen,
can I use the remaining GTPs for another application, when using a PCIe x1 port in the same GTP Quad? My application requires a x1 PCIe link and two GTPs for a custom application. The line rates of PCIe would be 5 Gbps and the custom GTPs need a line rate of 2.5 Gbps. The reference clock could be shared between them. I am worrying about the statements mentioned in PG054 v3.3 on page 176 ("Tandem PROM/PCIe Resource Restrictions"), which state that the entire Quad is lost for user application, when using PCIe. Does this only relate to the tandem configuration or is this a general issue, because the GTP common may not be used for another application, when using PCIe?
Thank you very much in advance.
Sincerely,
Martin Werner
saradapr
Hi @mwerner2000,
Please refer to the similar discussion:
https://forums.xilinx.com/t5/PCI-Express/Tandem-PROM-on-Zynq-DRC-place-errors/td-p/694203
https://forums.xilinx.com/t5/PCI-Express/Does-the-Tandem-constraints-include-slices-and-routing-resource/td-p/678115
Sarada
mwerner2000
Dear Sarada,
Thank you for your answer. I am not planning to use the Tandem configuration, because it is not available for Artix-7 FPGAs. I am just wondering if there is a technical reason, why the PCIe core should consume the other 3 GTPs in the same quad. Let's just assume I am not using tandem nor partial reconfiguration and the line rates of the PCIe and the other 2 GTPs will be the same. Can I use the other 3 GTPs for anything else than PCIe?
Sincerely,
Martin Werner
