06-09-2018 01:44 AM
I would like to transfer data from one PL to another PL. I would like to know the best approach for this purpose. I am aware that it may be possible to use a bram in standalone mode. However I did not find any example about it. I would like to know if it would be a stable mode of operation if I use bram in standalone mode. More explicity I would be using different clocks for write ( from one PL) and read (from the other PL) sequences hence does this lead to any data corruption or other adverse effects?
Thanks in advance.
Engin
06-09-2018 07:55 AM
Do you mean Pl ?
Pl is the FPGA side of the chip,
user programmable, logic design. So PL to PL is a unusual question.
06-09-2018 08:47 AM
Actually I believe it is a very critical question. If I am not able to directly share data between two PL units how can someone realize reasonable programming on FPGA without the intervention of PS. If I need PS to transfer data between two PL, it would not be efficient.
06-10-2018 11:26 AM
It is critical that it be done correctly, but it is an unusual question because you can program the PL to do (almost) anything you want.
Do your FPGAs have a common clock source? What is the rate of your data transfer? Is the transfer bi-directional or unidirectional? Do you want to use the AXI format, or something else? How many signal lines do you have, that is do you want a parallel bus or a serial link?
06-10-2018 10:08 PM
The first PL is a verilog unit operating at 3MHz, The other PL which I want to transfer data is a HLS unit which works at 100MHz. The data transfer would be unidirectional namely from the first PL to HLS. Note that I would like to have PL to PL transfer with no PS intervention. I believe serial link is more feasible since there will be a BRAM which is accessible one at a time.
06-10-2018 11:39 PM
06-11-2018 12:41 AM
Please note that there are no two FPGAs. Both PL are on the same FPGA. BRAM may be in standalone mode, dual port setting . I am not sure about the master and hope that this should be taken care of the BRAM generator.
06-11-2018 01:46 AM
I have feeling your approaching this from the perspective of software engineering,
PL is a Hardware design environment,
What you calling a PL, is in fact a design entity,
and multiple design entities are combined into the Pl to make the complete
In terms of software, think of them a 'functions'.
( OK hardware people dont shout at us )
In software, no matter how many functions you have, a function is no use on its own, you have to wrap around it other code.
in hardware , its the same,
You need to look at the IO interface of the blocks you have,
and what format they are in , and what tools you have to combine them,
