PLL DRC PDRC-43 issue
I tried to generate a clock with a PLL.
The input clock is a 119MHz and the outputs are 59.5 MHz and 416,5 MHz.
Via the Clock wizard i generate a PllE2_adv with the following parameters:
BANDWIDTH => "OPTIMIZED",
CLKFBOUT_MULT => 7,
CLKFBOUT_PHASE => 0.000000,
CLKIN1_PERIOD => 8.403000,
CLKIN2_PERIOD => 0.000000,
CLKOUT0_DIVIDE => 2,
CLKOUT0_DUTY_CYCLE => 0.500000,
CLKOUT0_PHASE => 0.000000,
CLKOUT1_DIVIDE => 14,
CLKOUT1_DUTY_CYCLE => 0.500000,
CLKOUT1_PHASE => 0.000000,
CLKOUT2_DIVIDE => 1,
CLKOUT2_DUTY_CYCLE => 0.500000,
CLKOUT2_PHASE => 0.000000,
CLKOUT3_DIVIDE => 1,
CLKOUT3_DUTY_CYCLE => 0.500000,
CLKOUT3_PHASE => 0.000000,
CLKOUT4_DIVIDE => 1,
CLKOUT4_DUTY_CYCLE => 0.500000,
CLKOUT4_PHASE => 0.000000,
CLKOUT5_DIVIDE => 1,
CLKOUT5_DUTY_CYCLE => 0.500000,
CLKOUT5_PHASE => 0.000000,
COMPENSATION => "ZHOLD",
DIVCLK_DIVIDE => 4,
IS_CLKINSEL_INVERTED => '0',
IS_PWRDWN_INVERTED => '0',
IS_RST_INVERTED => '0',
REF_JITTER1 => 0.010000,
REF_JITTER2 => 0.010000,
STARTUP_WAIT => "FALSE"
And then during implementation i got the following issue:
[DRC PDRC-43] PLL_adv_ClkFrequency_div_no_dclk: The computed value 455.000 MHz (CLKIN1_PERIOD, net Video_Clock) for the VCO operating frequency of the PLLE2_ADV site PLLE2_ADV_X1Y0
(cell i_LvdsTransmitter/i_LvdsTxClockGenerator/plle2_adv_inst) falls outside the operating range of the PLL VCO frequency for this device (800.000 - 1866.000 MHz).
The computed value is (CLKFBOUT_MULT_F * 1000 / (CLKINx_PERIOD * DIVCLK_DIVIDE)). Please adjust either the input period CLKINx_PERIOD (15.384615),
multiplication factor CLKFBOUT_MULT_F (7) or the division factor DIVCLK_DIVIDE (1), in order to achieve a VCO frequency within the rated operating range for this device.
Did you have an idea on how to solve this issue?
Best Regards,
pthakare
Hi @RomainDelcroix
This is bit unexpected using clocking wizard as M, D , and O values are getting set appropriately in clocking wizard.
Can you please share the clocking wizard .xci file , device part and VIVADO version used for this project.
As a workaround , check the cell properties of PLL and look for the values M (CLKFBOUT_MULT ) and  D (DIVCLK_DIVIDE)
VCO freq =  (input frequency * M)/O ,
Adjust the either M or O to have VCO frequency between (800.000 - 1866.000 MHz).
Running VCO at maximum frequency is recommended.
What did you mean by
I'm using vivado 2020.1
I don't reach to attached the xci files
The attachment's clk_wiz_0.xci content type (application/octet-stream) does not match its file extension and has been removed.
pthakare
Hi @RomainDelcroix
As per Input frequency and set output frequencies , clocking wizard will calculate the M , D and 0 values .
Fvco =  (Fin * M)/D
and Fout  = Fvco/0
Anyways can you please post here the screenshots for all tabs in the clocking wizard , Based on that i will check this at my end.
As suspect earlier , the set parameters in clocking wizard are not propogated properly in Implementation phase .
pthakare
Hi @RomainDelcroix
yes .xci attachement is not supported , you can create a zip and attach.
In fact i just used the wizard to define the parameters and then i instanciate the following blocks:
i_Pll : PLLE2_ADV
generic map(
CLKFBOUT_MULT => 7,
CLKFBOUT_PHASE => 0.0,
CLKIN1_PERIOD => 8.403,
CLKIN2_PERIOD => 8.403,
CLKOUT0_DUTY_CYCLE => 0.5,
CLKOUT0_PHASE => 0.0,
CLKOUT1_DUTY_CYCLE => 0.5,
CLKOUT1_PHASE => 0.0,
CLKOUT2_DIVIDE => 7,
CLKOUT2_DUTY_CYCLE => 0.5,
CLKOUT2_PHASE => 0.0,
CLKOUT3_DIVIDE => 7,
CLKOUT3_DUTY_CYCLE => 0.5,
CLKOUT3_PHASE => 0.0,
CLKOUT4_DIVIDE => 7,
CLKOUT4_DUTY_CYCLE => 0.5,
CLKOUT4_PHASE => 0.0,
CLKOUT5_DIVIDE => 7,
CLKOUT5_DUTY_CYCLE => 0.5,
CLKOUT5_PHASE => 0.0,
DIVCLK_DIVIDE => 1,
REF_JITTER1 => 0.100
port map(
CLKFBOUT => Feedback,
CLKOUT0 => TxClock_i,
CLKOUT1 => DualClock_i,
CLKOUT2 => open,
CLKOUT3 => open,
CLKOUT4 => open,
CLKOUT5 => open,
DO => open,
DRDY => open,
PWRDWN => '0',
LOCKED => Locked,
CLKFBIN => Feedback_i,
CLKIN1 => ClockIn,
CLKIN2 => '0',
CLKINSEL => '1',
DADDR => "0000000",
DCLK => '0',
DEN => '0',
DI => x"0000",
DWE => '0',
RST => Reset
pthakare
Hi @RomainDelcroix
This is not matching with instantiation you shared earlier where DIVCLK_DIVIDE = 4.
In current instantiation , DIVCLK_DIVIDE = 1 ,
 CLKIN1_PERIOD => 8.403  i.e input frequency Fin = 119 MHz
CLKFBOUT_MULT (M) = 7.
So the VCO frequency =  (119*7)/1 = 833 which is withing the limit
  CLKOUT0 = 833/2 = 416.5
  CLKOUT1 = 833/14 = 59.5
This instantiation should work .
Ok, but i have the following message
[DRC PDRC-43] PLL_adv_ClkFrequency_div_no_dclk: The computed value 455.000 MHz (CLKIN1_PERIOD, net Video_Clock) for the VCO operating frequency of the PLLE2_ADV site PLLE2_ADV_X1Y0 (cell i_LvdsTransmitter/i_LvdsTxClockGenerator/i_Pll) falls outside the operating range of the PLL VCO frequency for this device (800.000 - 1866.000 MHz). The computed value is (CLKFBOUT_MULT_F * 1000 / (CLKINx_PERIOD * DIVCLK_DIVIDE)). Please adjust either the input period CLKINx_PERIOD (15.384615), multiplication factor CLKFBOUT_MULT_F (7) or the division factor DIVCLK_DIVIDE (1), in order to achieve a VCO frequency within the rated operating range for this device.
I don't understand why the CLKINx_PERIOD is 15.384615?
pthakare
Hi @RomainDelcroix
Yes this unexpected .
Can you please open the implemented design , -> Check the PLL in the netlist -> Check the cell properties.
I believe the CLKINx_PERIOD  is wrongly propagated, you can edit the  "CLKINx_PERIOD" attribute in cell properties to actual CLKIN_PERIOD
and re run the implementation.
How i can do that the implementation section is not accessible? And I don't find the Check the cell properties.
On this design i have an other PLL, who provide the 119MHz. It's an issue?
It's not solving the issue
pthakare
Hi @RomainDelcroix
#1 Open the Schematic after implementation ,
#2 Search for the PLL in discussion ,
#3 Check the cell properties for that PLL  (i.e CLKIN_PERIOD, M , D value)
You will observe that it is not matching with parameters set by wizard.
#4 edit the incorrect CLKIN_PERIOD property with correct CLKIN period  and re-run the implementation.
Ok, I remove one of the two PLLs and it solve my issues. Changing the settings was not solving the problem.
Arkque
Hi Newbie,
I'm facing the same issue. Plz explain me step by step how you proceed to solve this issue.
Thank you
