09-03-2014 06:31 PM
I created a core instance of XADC with XADC Wizard (3.0) and I instantiated it like this:
... component temperatureMonitor port ( daddr_in: in std_logic_vector(6 downto 0); dclk_in: in std_logic; den_in: in std_logic; di_in: in std_logic_vector(15 downto 0); dwe_in: in std_logic; busy_out: out std_logic; channel_out: out std_logic_vector(4 downto 0); do_out: out std_logic_vector(15 downto 0); drdy_out: out std_logic; eoc_out: out std_logic; eos_out: out std_logic; ot_out: out std_logic; alarm_out: out std_logic; vp_in: in std_logic; vn_in: in std_logic ); end component; ... temperature_monitor_instance: temperatureMonitor port map ( daddr_in => monitorAddress, dclk_in => Clock36M, den_in => monitorDen, di_in => monitorDataIn, dwe_in => logicZero, busy_out => open, channel_out => open, do_out => monitorDataOut, drdy_out => monitorDrdy, eoc_out => monitorEoc, eos_out => open, ot_out => monitorOverTamperatureAlarm, alarm_out => open, vp_in => logicZero, vn_in => logicZero ); ...
When implementing the design with Vivado 2014.2 I get this error:
[Place 30-99] Placer failed with error: 'There are more instances than sites for type XADC' Please review all ERROR, CRITICAL WARNING, and WARNING messages during placement to understand the cause for failure.
The target device is xc7a200tfbg484-3.
Any ideas what am I doing wrong?
09-03-2014 09:40 PM - edited 09-03-2014 09:41 PM
HI,
Disable XADC option in MIG and connect the signals from externally instantiated XADC, please refer UG586 and AR-51687 section "Designs already Using XADC" for more info
http://www.xilinx.com/support/answers/51687.html
Hope this helps
Vanitha
09-03-2014 08:37 PM
09-03-2014 09:08 PM
Not sure of your other modules, if your design has any IPs like MIG that already calls XADC yo may not be able to use it again, please cross check!
Vanitha
09-03-2014 09:29 PM
Hi Vanitha,
Yes, I use MIG IP.
If it uses the XADC, how could I access the temperature XADC channel?
Vlad
HI,
Hope this helps
Vanitha
09-04-2014 12:33 AM
Thanks Vanitha,
This solved my problem.
Vlad
