Power consumption of a rarely called task
I am new here and this is my first post.
I am using Vivado 2018.2,  Artix7 and SystemVerilog.
Does the hardware that actually performs a task (a task in SystemVerilog sense) consume energy when it is not active?
Can I use tasks to consume power only when needed?
Can it be that the synthesizer automatically employs the CE "pins" on the FFs in the task?
Thank you.
Miklos
Re: Power consumption of a rarely called task
Understand the entire device has some (not small) static power,
The few blocks than can be power gated (unused BRAM) are automatically powered down if not used.
Generally speaking FPGA devices do not have many static power saving features (too area intensive, so not done).  Instead clock gating is used to save dynamic power when a design is equipped to do so (the design uses clock gating provided by the BUFGCE).
Clock enables on the various tiles (DFF, BRAM, DSP, etc.) generally saves little dynamic power.
FPGA devices ar erarely used in low power applications, as they are not low power devices at all  (as compared to devices that are actually designed for low power applications).
l.e.o.
Hello New Here,
Yes, Vivado implementation tools should automatically performs clock gating on portions of your design where it best makes sense to do. Feel free to read the two white papers linked below for more information regarding this Xilinx tools feature.
https://www.xilinx.com/support/documentation/white_papers/wp389_Lowering_Power_at_28nm.pdf
https://www.xilinx.com/support/documentation/white_papers/wp370_Intelligent_Clock_Gating.pdf
T
l.e.o.
Thank you indeed for your swift response.
