Problem while generating frequency generation
I would like to generate variable  frequency using  Artix-7 from 1.6 MHz to 2.3 MHz with a resolution of 0.001 MHz. My clock frequency is 100 MHz. I am able to generate fix frequency in this range using reference design of MMCM-DRP access. But I am unable to vary CLKFBOUT_MULT_F, DIVCLK_DIVIDE, CLKOUT0_DIVIDE_F using program. These parameter accept only constant value. Perhaps, I am unable to change verilog code.
Please suggest better way to generate the variable frequency from 1.6 MHz to 2.3 MHz with a resolution of 0.001 MHz.
Re: Problem while generating frequency generation
What do you want to use the frequency for? You might want to look into different DDS-Style algorithms to generate either the clock (if you want to output the waveform to another IC) or a clock enable (if you want to use it as an internal clock).
Beware that this basically distributes the frequency error around at a granularity of 1 clock cycle of your reference clock, so in your case, you will see jitter in increments of 10 ns.
10 ns jitter is not acceptable
If you have an Ultrascale device, you could probably multiply your 100MHz clock up to 400MHz and use @klasha's DDS idea.  This would reduce the deterministic jitter to 2.5nS.  What jitter is acceptable?  Just an observation, you are looking at producing clocks with a period difference of 2.5x10e-16 seconds.  I don't think that you could run a PLL in an FPGA fast enough to give you the resolution you want.
At first glance what I want to achieve looks impossible in a fpga.
But
There are some very clever people on here.
Give them some idea as to your total system design , and they might be able to stear you .
