Anonymous
Not applicable
Problem with Reference design ZedBoard
I have tried chapter 2 tutorial using Vivado SDK and ZedBoard with wondows 7 machine from the Reference Design Tutorial which is available in attachment, and can also be found from the lik below.
"Zynq Concepts, Tools, and Techniques on ZedBoard"
http://zedboard.org/support/design/1521/11
The chapter 2 tutorial works well but there is a problem with tutorial in chapter 3. I have followed all the steps of this tutorial until Figure 3-7 on page 42. The blue DONE LED light turns  up according to point number 10 but nothing appears on the Tera Term termina, l even I could not type anything on the tera terminal.
Re: Problem with Reference design ZedBoard
Are you using 2014.2?
Austin Lesea
Principal Engineer
Xilinx San Jose
Anonymous
Not applicable
I am using Vivado 2015.4
Anonymous
Not applicable
Before reference design I also have tried all demos on ZedBoard mentioned in Getting Started Guide "GS-AES-Z7EV-7Z020-G-V7" available in attachment. All demos works well even including these which require Term Tera.
Are you going for run configuration or debug??
Anonymous
Not applicable
I am running Chapter 3 "Embedded system design using the Zynq Processing System and Programmable Logic" which is configuration mode I guess not debug mode.
Have you connected the teraterm correctly? Choose right port?? Set the baud rate correctly?? If you have you are probably missing something in the design.
Anonymous
Not applicable
All settings are ok. Now it works. The problem was with preset Zynq PS IP before validating design. It was not done properly.
I have another question regarding interfacing with DDR 3 memory on ZedBoard. Is is necessary to involve PS to communicate with DDR memory ? Is there any IP available to send or receive the data from Zynq to DDR ?
I am sorry @Anonymous. I didnt understand your question.
