Programming via GPIO pins
I have PCB with Artix-7 FPGA and other components including flash and has CMOS connection via 8 lines to FPGA GPIO pins. How can I configure/program/load this unprogrammed FPGA (no previous bitstream or mcs image loaded) with GPIO pins? Note that, I don't have access to the JTAG port and configuration mode pins M2, M1, M0 are (001) in the design.
Tags (4)
Hi @amkichu
You can configure FPGA device only through configuration pins of FPGA.
For more details check https://www.xilinx.com/support/documentation/user_guides/ug470_7Series_Config.pdf
Bhushan
Bhushan
Hi @amkichu
Bhushan
Bhushan
