Visitor jcrash29
QSPI free space
Does my Bare Metal application have access to the QSPI that is used to load the system? Can I store and load data from the Flash? How much space? Starting at what address?
回复: QSPI free space
Hi @jcrash29
If you want to configure the QSPI as the boot media, firstly, you should create a BOOT.bin/mcs file which includes fsbl.elf, bitsteam(if you have a PL design) and <your application>.elf using Xilinx Tools->Create Zynq Boot Image tool in XSDK.
Then, program the generated BOOT.bin/mcs into your QSPI flash using  Xilinx Tools-> Program Flash tool in XSDK.
If you want to store your own data, you should create your own application to read/write QSPI flash. Furthermore, you can pre-store your data in QSPI flash by adding that in BOOT.bin/mcs, specifying an offset address when you create the boot image.
回复: QSPI free space
Hi @jcrash29
Are you using an FPGA(I mean devices like Artix-7/Kintex-7/Virtex-7) or an SoC device(Zynq-7000 or MPSoC)?
QSPI Flash can be used as a boot media on both kinds of devices.
Visitor jcrash29
回复: QSPI free space
I am using a Zynq-7000 chip.
回复: QSPI free space
Hi @jcrash29
