stgateizo
Question about BUFR "Divide by 1" Mode in Kintex7
Dear colleagues,
I have a question about the BUFR primitive in a Kintex7 device.
When I use the BUFR in "divide by 1" mode, can it happen that the phase between input and output clock can be either 0° or 180°, in dependcy when CE is released related to the input clock?
Best regards
stgateizo
joancab
I don't think so. Fig 2-22 in UG472 may hold some clues. Keep in mind that divide by 1 and bypass are different in terms of delay (thus phase)
stgateizo
Hi joancab,
well I have made some tests now, and it seems that there can happen a phase shift of 0° or 180°, in dependecny if  CE is going high with a rising, or falling input clock edge. I set now the BUFR into "Bypass" mode, and now the pahse shift is stable (zero phase shift).
stgateizo
joancab
That's quite interesting. I would prefer to think you violate some timing requirements in one of these experiments. How do you measure phase? What frequency?
stgateizo
Hi joancab,
I cannot measure the phase directly, but let me explain why I think that the behavior is as I have described as before:
  1. I use the BUFR in the input clock path, in order to clock in data with an IDDR primitive. When I set the BUFR attribute BUFR_DIVIDE <= "1", then the divide by 1 mode is active. In this case, after power-on I can sometimes see that data are provided in the wrong order (IDDR output Q1 and Q2 are mixed up) with a probabiltiy of 50%. When I set the BUFR attribute BUFR_DIVIDE <= "BYPASS", then the data are always in the correct order at Q1 an
  2. When you look to figure 2-22 below (or ug472 page 53), you can see that the input clock edge, which follows after CE goes high will lead to a rising clock edge on the output. So if the input clock edge is a rising clock edge the phase will be 0°. If the input clock edge was a falling clock edge, the pahse can be 180°.
    Of course it is not exactly 0° or 180°, since the BUFR itself has probably also some latency.
Well if you don't belive it, please make a little example design, where you route the clock before the BUFR and after the BUFR to any output pins, and measure the phase shift, after each power-cycle. You have to load the FPGA from FLASH for this scenario... You will not see this issue when you use JTAG for loading the FPGA...
Well i have not the time for doing such basic tests. I already spent too much effort for debugging this issue, and you know time is money.
Best regards
stgateizo
joancab
I agree with your way of measuring phase. So you mean CE is captured at both input clock edges and output comes after so it can have that 0/180 phase. It looks like something Xilinx could be interested in, at least, document to warn people in the future.
stgateizo
Hi joancab,
well the default value is "BYPASS". I think most developers even do not know that you can use it as divider. But when you use it as divider, you are faced to this beahvior...
Kind regards
stgateizo
When you toggle CE on the BUFR, it will behave differently for BUFR_DIVIDE=BYPASS and BUFR_DIVIDE=1.
For example, when you toggle CE, the output of the BUFR with BUFR_DIVIDE=BYPASS may start with a falling clock edge whereas the output of the BUFR with BUFR_DIVIDE=1 may start a little later with a rising clock edge.
However, the BUFR input and output clock will always end up very nearly phase-aligned whether you use BUFR_DIVIDE=BYPASS or BUFR_DIVIDE=1.
It is best to control the startup of BUFR-produced clocks using the BUFR Alignment method described in Appendix A of UG472.  This Alignment is especially important if you are using BUFR_DIVIDE values greater than 1, otherwise the phase relationship between clock outputs from separate BUFR could change every time you power-up the FPGA.
In short, the BUFR Alignment method is:
  • all BUFR are fed from a common buffer with CE (typically BUFMRCE)
  • set CE=1 on all BUFR
  • stop the clock input to all BUFR using CE=0 on BUFMRCE
  • toggle the CLR pin on all BUFR
  • start the clock input to all BUFR using CE=1 on BUFMRCE
Cheers,
Mark
stgateizo
Hi Mark,
your statement "However, the BUFR input and output clock will always end up very nearly phase-aligned whether you use BUFR_DIVIDE=BYPASS or BUFR_DIVIDE=1. ", does not match to my experiences.
Well I only chagned the BUFR from "Divide by 1" to "Bypass", and I was able to sample the data properly.
As long as nobody is preparing an example design, which allows you to check the phase realtionship with an external oscilloscope, I do not belive it.
Kind regards
stgateizo
