Visitor tyler.wilson
Reading a differential signal into the Kintex 7 KC705
I am attempting to read a differential signal into the FPGA: i_SCLK_P and i_SCLK_N. I want to trigger my ILA on a rising edge of i_SCLK. I am unable to contrain my pins correctly. I am getting the following error:
  • [Place 30-64] Illegal IOStandard configured for port 'i_SCLK_N'. I/O port 'i_SCLK_N' is differential, but has single-ended IOStandard value LVCMOS25.
I have then attempted to change my IOStandard to LVDS (which I have attached) but I then get the following error:
  • [Drc 23-20] Rule violation (BIVB-1) Bank IO standard Support - Bank 16 has incompatible IO(s) because: The LVDS I/O standard is not supported. Move the following ports or change their properties: i_SCLK_P
I have tried to change to a different bank twice now. I was hoping that I could find a bank with LVDS capability. I have looked through the KC705 datasheet and it appears that the pins that I am using should be valid.
Where am I going astray? Thanks for the help!
Scholar pratham
Re: Reading a differential signal into the Kintex 7 KC705
@tyler.wilson can you consider D26 and C26 MRCC pins for the clock instead of H26 and H27.
If you want to use H26 and H27 only you may have to use this in your xdc to bypass the placement error
set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets i_SCLK]
-Pratham
I will also say that I am attempting to instantiate an IBUFDS as follows:
wire i_SCLK;
IBUFDS #(
.CAPACITANCE("DONT_CARE"),
.DIFF_TERM("FALSE"),
.IBUF_DELAY_VALUE("0"),
.IFD_DELAY_VALUE("AUTO"),
.IOSTANDARD("DEFAULT")
) IBUFDS_inst (
.O(i_SCLK),
.I(i_SCLK_P),
.IB(i_SCLK_N)
Scholar pratham
@tyler.wilson bank 16 is HR bank Try LVDS_25 this should work
-Pratham
Hello @tyler.wilson,
Which Vivado version are you using? Can you try in Vivado 2015.2
Does your design contains MIG core?
Also check if the following thread is helpful:
http://forums.xilinx.com/t5/7-Series-FPGAs/K7-problem-of-HR-BANK-LVDS-signals-selected/m-p/523965
--Syed
Thank you. I changed my XDC file to say LVDS_25 and now I have a new error:
  • [Place 30-574] Poor placement for routing between an IO pin and BUFG. If this sub optimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .xdc file to demote this message to a WARNING. However, the use of this override is highly discouraged. These examples can be used directly in the .xdc file to override this clock rule. < set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets i_SCLK] > IBUFDS_inst (IBUFDS.O) is locked to IOB_X0Y254 and i_SCLK_BUFG_inst (BUFG.I) is provisionally placed by clockplacer on BUFGCTRL_X0Y31
What does this mean?
I am using Vivado 2014.2
Can you attach your post synthesis dcp file here?
--Syed
Scholar pratham
@tyler.wilson Look here
https://www.google.co.in/search?q=Place+30-574&oq=Place+30-574&aqs=chrome..69i57j69i60&sourceid=chrome&es_sm=93&ie=UTF-8#q=Place+30-574+site:forums.xilinx.com
-Pratham
Attached is the dcp file. I hope it was the one that you were looking for
Also, attached is my top design verilog file.
I get the following CW, when i open the attached dcp file:
CRITICAL WARNING: [Project 1-486] Could not resolve non-primitive black box cell 'clk_wiz_0' instantiated as 'clk_wiz_0' [C:/Users/dmg7145/Documents/Varian_Projects/hdl-hdl_2014_2/projects/fmcomms1_V55_Inputs/kc705/fmcomms1_kc705.srcs/sources_1/new/test0.v:51]
CRITICAL WARNING: [Project 1-486] Could not resolve non-primitive black box cell 'ila_0' instantiated as 'ila_0' [C:/Users/dmg7145/Documents/Varian_Projects/hdl-hdl_2014_2/projects/fmcomms1_V55_Inputs/kc705/fmcomms1_kc705.srcs/sources_1/new/test0.v:59]
Can you check this thread and see if it helps:
http://forums.xilinx.com/xlnx/board/crawl_message?board.id=IMPBD&message.id=10157
--Syed
From the .dcp file it looks like you are using user IO pins instead of SRCC/MRCC pins.
Please change your design to place clock signal on clock pins.
Anusheel
Helpful answer -> Give Kudos
Scholar pratham
-Pratham
Thanks for the help everyone! It seems to be working great now!
Some more additional information that might be helpful to more newbie users (like myself). I had multiple input signals that were not clocks but I was using them in always blocks like this:
always @(posedge my_signal_name) begin
   blah blah blah;
end
I was unaware that when you are trying to trigger on a posedge of a signal in that manner, that it expects the pin to be a clock signal. Hence, I needed to connect my signal to a clock capable pin. So my alternative and fix to my problem was as follows:
always @(posedge sys_clk) begin
      if ( my_signal_name == 1) begin
              blah blah blah;
      end
end
I  hope that this helps others like me!
