Relation between Speed Grade and Electromagnetic susceptibility
Hi All,
I need to choose Artix 7 device for Industrial environment applicaiton with very high EMI interference. So, before going ahead with final selection, wanted to know if there is any relation between speed grade of device and Electromagnetic susceptibility?
If yes, what are the levels for that?
Vishal
csattar
hi @vishald.prajapati ,
i believe and assume there is no relationship between them .
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
csattar
Chandra sekhar
I would say these are totally unrelated. Speed grades come from screening, I think.
