Requirement for Differential Clock IOs
Hi all
In ds182,I only find the issues about about GTX Reference clock,that should be focused on.What should be considered When I use an oscillator to connect the Clock capable IOs?
Re: Requirement for Differential Clock IOs
@chenxuol Not sure if you mean what are the specs of the clock generator you should be looking for to drive Clock capable I/O's.
If so, first it depends on what frequency you planning to use, check what IO standards it can output (generally LVDS is preferred) and check its Jitter values
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
Hi @chenxuol
See whether clocking resources user guide helps you: https://www.xilinx.com/support/documentation/user_guides/ug472_7Series_Clocking.pdf
Also post your exact query.
Vinay
you just need to make sure use correct PIN number and use proper clocking constraints . Check this guide
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug903-vivado-using-constraints.pdf
https://www.xilinx.com/video/hardware/creating-basic-clock-constraints.html
Thanks and Regards
Balkrishan
- Giri
Hi,@Moderator
I want to check whether the output voltage of the oscillator can meet Clock capable I/Os.I have found the description in ds182,Table 12: LVDS_25 DC Specifications.
Thanks!
@chenxuol Thanks for the clarification. Since LVDS is not a rail to rail standard, the main conditions that need to be checked are if VOD (Output Differential Voltage) and VOCM (Output Common Mode Voltage) of transmitter (in your case the clock chip) are within limits of VID (Input Differential Voltage) and VICM (Input Common Mode Voltage) of the receiver (in your case Kintex) given in Table 12 as you mentioned.
Just FYI, LVDS_25 is for HR banks (2.5V) while LVDS is for HP banks (1.8V). Both have similar specs though.
- Giri
