SOME QUESTIONS ABOUT THE PCIE BRIDGE! k7420T-FF901
If I use the "MTG115(G11  supply groups)" as a pcie-bridge, can I set the unsued power pins of the G10 supply groups to the GND? 7 SERIERS K420T-FFG901.
     In the following pictures,  The  power pins of the G10 groups(no use) are set to the gnd, because the G11 group contains the pcie-bridge (GTX115)
       The  power pins of the G10 groups are set to the gnd, because the G11 group contains the pcie-bridge (GTX115)
Re: SOME QUESTIONS ABOUT THE PCIE BRIDGE! k7420T-FF901
Wandtdk,
Yes. You should be good to go since the RCAL is also in G11 with your PCI-E bridge. RCAL power group always needs to be up for the transceiver in that RCAL group to work properly.
Tezz
Thank you!
