Bruno68
SP701 spartan 7 - Internal clock using through SI570BAB000875DG
We are using SP701 for a spartan 7 xc7s100fgga676-1 evaluation Kit.
We would like to use the component Silicon Labs SI570BAB000875DG embedded on the board.
We know that this component generate by default a 33 MHz clock.
Currently, we try to observe this clock divided by 1000.
As you can see, we have instantiated IBUFDS
and the constraint file is :
Unfortunately, we can't manage to observe the clock divided.
Is someone has a solution?
Thank you in advance
Best Regards
bruce_karaffa
How are you trying to observe the output, an oscilloscope?  What do you see?  As an aside, if you post your code using the Insert/edit Code icon </>  the code will be more readable than a screenshot.
Bruno68
Finally, we manage to observe the clock divided by 200. Input signal level was 2.5V instead of 3.3V.
But I notice that the frequency of the output is 1MHz that means that the default frequency of the component  SI570BAB000875DG is 200MHz and not 33MHz.
Have you ever seen this ?
Here below, constraint file :
set_property LOC AE8 [get_ports input_p]
#set_property PACKAGE PIN AE8 [get_ports input_p]
set_property IOSTANDARD LVDS_25 [get_ports input_p]
set_property DIFF_TERM TRUE [get_ports input_p]
set_property LOC AE7 [get_ports input_n]
#set_property PACKAGE PIN AE7 [get_ports input_n]
set_property IOSTANDARD LVDS_25 [get_ports input_n]
set_property DIFF_TERM TRUE [get_ports input_n]
set_property LOC E11 [get_ports output_1]
#set_property PACKAGE PIN E11 [get_ports output_1]
set_property IOSTANDARD LVCMOS18 [get_ports output_1]
set_property LOC E6 [get_ports LogresL]
set_property IOSTANDARD LVCMOS18 [get_ports LogresL]
set_property LOC M7 [get_ports LogresL_out]
set_property IOSTANDARD LVCMOS18 [get_ports LogresL_out]
Here below, vhdl code :
LIBRARY ieee;
USE IEEE.std_logic_1164.ALL;
USE IEEE.std_logic_unsigned.ALL;
--LIBRARY LIB_PROTO;
--USE LIB_PROTO.pack_proto_top.ALL;
library UNISIM;
use UNISIM.vcomponents.all;
ENTITY proto_charge_top IS
PORT (
         LogresL         : IN STD_LOGIC;
         --CLOCKS
         input_p         : IN  STD_LOGIC;
         input_n         : IN  STD_LOGIC;
         LogresL_out     : OUT STD_LOGIC;
         output_1        : OUT std_logic
END proto_charge_top;
ARCHITECTURE rtl OF proto_charge_top IS
SIGNAL cpt          : std_logic_vector(7 downto 0);
SIGNAL output_1_loc : std_logic;
SIGNAL Clock        : std_logic;
CONSTANT CST_100    : std_logic_vector(7 downto 0):="01100100";
CONSTANT CST_1      : std_logic_vector(7 downto 0):="00000001";
BEGIN
output_1    <= output_1_loc;
LogresL_out <= LogresL;
IBUFDS_inst : IBUFDS
generic map (
     diff_term => true,
     ibuf_low_pwr => true,
     iostandard => "default"
PORT MAP (
      O => Clock,
      I => input_p,
      IB => input_n
PROCESS(LogresL, Clock)
BEGIN
  IF LogresL = '0' THEN
    cpt          <= (OTHERS => '0');
    output_1_loc <= '1';
  ELSIF rising_edge(Clock) THEN
    cpt <= cpt + "01";
    IF cpt = CST_100 THEN
      output_1_loc <= not(output_1_loc);
      cpt <=  CST_1;
    END IF;
  END IF;
END PROCESS;
END rtl;
Best Regards
Bruno.
