pavel_47
Voyager
Voyager
Search for a document with detailed pin description for 7-seies
Does exist a document where I can find information on special pins for 7-series
I looked into ug470 and didn't find info on special pins of bank14.
rsey
ug475 might help.
\Razi
-- Don’t forget to Reply, Kudo, and Accept as Solution --
dpaul24
@pavel_47,
Perhaps if you are more specific on which series7 you want to use, the easier would it be to provide info about the exact docu.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
pavel_47
Voyager
Voyager
Artix, pin K12
bruce_karaffa
What package?  What is the name of the pin, something like M0, INIT_B...
pavel_47
Voyager
Voyager
BGA256, IO_0_14
pavel_47
Voyager
Voyager
XC7A15T-3FTG256E
