Signal initialization in Virtex II (XC2VP50) with ISE 10.1i
I have seen recent posts verifying that in modern tools and devices the following VHDL signal instantiation will have an initial value after configuration of '1', but does this hold true for older devices and tools?
Specifically the VirtexII Pro (XC2VP50) and ISE 10.1i ?
signal enable : std_logic := '1';
Will my signal "enable" have the value of '1' after configuration without any reset block?
回复: Signal initialization in Virtex II (XC2VP50) with ISE 10.1i
Hi dwalto08@harris.com
Yes, the initial state after configuration is 1 for signal enable.
Simon
Simon
Thank you Simon. I could find no documentation of that in the datasheet, appnotes, or white papers that specifically addressed Virtex II.
