rohithcs
Simple connection between LED and switch
I have been new to the usage of Kintex-7. I am trying to implement an AND Gate with 2 dip switches as Input and LED as an output. The following is the program i had written for this implementation
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 10/06/2017 12:45:45 PM
// Design Name:
// Module Name: top
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module top(
a,
b,
c
input a;
input b;
output c;
assign c = a && b;
endmodule
and the corresponding xdc file is
set_property PACKAGE_PIN W29[get_ports a]
set_property IOSTANDARD LVCMOS25[get_ports a]
set_property PACKAGE_PIN Y29[get_ports b]
set_property IOSTANDARD LVCMOS25[get_ports b]
set_property PACKAGE_PIN AA8[get_ports c]
set_property IOSTANDARD LVCMOS15[get_ports c]
set_property BITSTREAM.General.UnconstrainedPins {Allow} [current_design]
The program gets Synthesized and Implemented, I am also able to generate the bit stream, but this programmed FPGA is unable to show the characteristics of AND Gate.
Any help  would be appreciated
a_chami
I would try by deleting this line:
If once deleted you receive errors, please share here what those errors are
Avi Chami MSc
FPGA Site
