Visitor jrusse42
Spartan 3A example codes
If anyone out there is working with or have worked with Spartan 3A FPGA and has some example project to share I would appreciate seeing whatever code you can provide. So far I've only come across LED counter examples and nothing else which would demonstrate the use of the features of the board.  Thanks in advance.
regards,
Jeff
Scholar jmcclusk
Re: Spartan 3A example codes
Try this link and search for the downloadable zip files with design examples.  Not all are Spartan3A, but some of them are.
Scholar u4223374
If you want examples showing the features of the board, you're going to have to tell us which board you're using. Is it the Spartan 3A Starter Kit? Avnet's Spartan-3A Evaluation Kit, or their DaVinci Development Kit? The Numato Elbert V2?
Visitor jrusse42
Thanks for the response. My package said Elbert - Spartan 3A FPGA development board. I purchased it from Numato Lab and its said that its a version 1.02
is this the board:
https://numato.com/product/elbert-v2-spartan-3a-fpga-development-board
If so this is not a Xilinx board, so the files mentioned by @jmcclusk will not be directly compatible, however, you could use them as a reference.
I would suggest asking Elbert directly as they have their own forums and developer section.
