Spartan 6 Block Memory Reset
I am using the block ram in a Spartan 6 FPGA.
I used the IP Core Generator to create the Verilog model.
Ram block used as Simple Dual Port.
I want to be able to clear the ram's content but I don't see a PortA Reset selection using the IP Core Generator even though it is discussed in many Xilinx documents and it is part of the Verilog model generated.
Can a Simple Dual Port implementation of a Ram Block be reset/cleared?
Re: Spartan 6 Block Memory Reset
The reset doesn't clear the RAM array itself - it only clears the respective output registers.
You'll likely need to write back over the contents explictly.
For more info: https://www.xilinx.com/support/documentation/user_guides/ug383.pdf
