darshanvenkat
Spartan 6 EVA Board and GPX2 TDC interface
Hello guys,
I have built a TDC circuit using the GPX2 TDC chip. Now I want to control it using Spartan 6 to perform TDC operation using differential signals. I have bought a Xilinx FMC debug card to connect the TDC to the FPGA, Now I am stuck in figuring out what pins I have to connect from the TDC to FPGA (FMC Card). Can some one please help!
TDC Datasheet: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiIm6PF-4nXAhWk3YMKHROCDvQQFggoMAA&url=https%3A%2F%2Fams.com%2Fger%2Fcontent%2Fdownload%2F951531%2F2270299%2Ffile%2FTDC-GPX2_DS000473_1-00.pdf&usg=AOvVaw3242Ql8e...
csattar
Hi @darshanvenkat,
can  you share the block diagram which your planning to implement, which bank your interfacing  let us know bank details for which you want to share .
thanks
S.chandra sekhar
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
darshanvenkat
Hi @csattar,
Thanks for replying, I am trying to connect the FRAME (LVDS) PINS on the TDC to the LVDS pins on the FPGS's FMC
TDC Diagram is attached. Can you let me the what are the LVDS pins on the Spartan 6 EVA605 board to connect the FRAME1 N and FRAME1 P?
csattar
HI @darshanvenkat.
thanks for the update . can you once check with which bank your interface this Card and can you  let us know the bank , also check that s that supports the LVDS . How did you bulid the XDC constraint for this frame pins I see in the data sheet there are connected to serializer then you can use the LVDS and once check the XAPP1064 (v1.2) November 19, 2013 Source-Synchronous Serialization and Deserialization (up to 1050 Mb/s) .
Thanks and regards,
S.chandra sekhar
SR Product Application Engineer , WTS , Xilinx
Chandra sekhar
darshanvenkat
 Hi @csattar This is how I am doing the constraints:
are they good to go?
csattar
hib @darshanvenkat
My dear friend please specify the bank number and fpga part number your using .
Chandra sekhar
xinxiangwanji
Hi @darshanvenkat,
    I have some qiestions about TDC_GPX2 want to ask you!I uesing the TDC_GPX2,I can write the register and raed the data from the register through the SPI interface, the data read and wite is same,but i can not receice the result from the "Fram e & SDO" interface,Coule you helping me ?
