Visitor camelliaszl
Spartan 6 multi-clock Configuration
Hi, guys~
Is it possible to generate 3 clocks from CMT by using a single external clock source (32.768M Hz) on XC6SLX9 ?
       1) 131.072M
       2) 100M
       4)  65M
回复: Spartan 6 multi-clock Configuration
Hi @camelliaszl
You can check this in clocking wizard as below:clocking.JPG
Simon
Visitor camelliaszl
Hi, Simon:
    I have worked it out~
    Accurate frequency is very important for my design, so i chained 2 PLLs & 4 DCMs together to generate these clocks i needed.
   Thanks for your reply~
Participant mwerner2000
Dear camelliasz,
you stated that the clocks must be very frequency accurate. What exactly are going to use these clocks for?
Best regards,
Martin
