Spartan 7 LVDS_25 input data rate
Hi Xilinx,
I am going to choose XC7S75-2FGG484 to receive 16 channels LVDS data (DDR mode) and 1 LVDS clock. The target speed is 1Gbps for each channel. I am considering to connect to Bank 13 because of system design.
1. Can Spartan 7 support the 1Gbps data rate?
2. Is there any limitation to use Bank 13? Since the IO number is smaller than other banks.
回复: Spartan 7 LVDS_25 input data rate
@xjtusiriusHi,
Please check the answer below:
Ans: You can check the DS189 Table15 the -2 speed device can support 1250Mb/s@ DDR, -1 speed device only support 950Mbps. If you need to design the board, SI also need to be considered.
Ans: Some bank have fewer IO because not all pin fanout from the chip die. These pins are normal user IO as other bank's.
@xjtusiriusHi,
