Spartan6 with DDR3 IOB conflict
we successfully employed the MIG with a DDR2 memory connected on bank1.
Now I'm trying to upgrade to DDR3, so I changed the UCF file according to newer I/O standard requested (I simply copied relevant data from the UCF generated by core_generator).
NET  "dram_reset_n_out"       IOSTANDARD = SSTL15_II;
NET  "dram_ck_out"            IOSTANDARD = DIFF_SSTL15_II | OUT_TERM = UNTUNED_50;
NET  "dram_ck_n_out"          IOSTANDARD = DIFF_SSTL15_II | OUT_TERM = UNTUNED_50;
NET  "dram_cke_out"           IOSTANDARD = SSTL15_II | OUT_TERM = UNTUNED_50;
NET  "dram_a_out[*]"          IOSTANDARD = SSTL15_II | OUT_TERM = UNTUNED_50;
NET  "dram_ba_out[*]"         IOSTANDARD = SSTL15_II | OUT_TERM = UNTUNED_50;
NET  "dram_ras_n_out"         IOSTANDARD = SSTL15_II | OUT_TERM = UNTUNED_50;
NET  "dram_cas_n_out"         IOSTANDARD = SSTL15_II | OUT_TERM = UNTUNED_50;
NET  "dram_we_n_out"          IOSTANDARD = SSTL15_II | OUT_TERM = UNTUNED_50;
NET  "dram_odt_out"           IOSTANDARD = SSTL15_II | OUT_TERM = UNTUNED_50;
NET  "dram_dq_inout[*]"       IOSTANDARD = SSTL15_II | IN_TERM = NONE | OUT_TERM = UNTUNED_50;
NET  "dram_dm_out"            IOSTANDARD = SSTL15_II | OUT_TERM = UNTUNED_50;
NET  "dram_udm_out"           IOSTANDARD = SSTL15_II | OUT_TERM = UNTUNED_50;
NET  "dram_dqs_inout"         IOSTANDARD = DIFF_SSTL15_II | IN_TERM = NONE | OUT_TERM = UNTUNED_50;
NET  "dram_dqs_n_inout"       IOSTANDARD = DIFF_SSTL15_II | IN_TERM = NONE | OUT_TERM = UNTUNED_50;
NET  "dram_udqs_inout"        IOSTANDARD = DIFF_SSTL15_II | IN_TERM = NONE | OUT_TERM = UNTUNED_50;
NET  "dram_udqs_n_inout"      IOSTANDARD = DIFF_SSTL15_II | IN_TERM = NONE | OUT_TERM = UNTUNED_50;
NET  "dram_rzq_inout"         IOSTANDARD = SSTL15_II | OUT_TERM = UNTUNED_50;
NET  "dram_zio_inout"         IOSTANDARD = SSTL15_II | OUT_TERM = UNTUNED_50;
While it worked as expected with DDR2 and VCCO=1.8, now ISE gives an error I don't understand:
ERROR:Place:864 - Incompatible IOB's are locked to the same bank 1
   Conflicting IO Standards are:
   IO Standard 1: Name = SSTL15_II, VREF = 0.75, VCCO = 1.50, TERM = NONE, DIR =
   BIDIR, DRIVE_STR = NR
   List of locked IOB's:
       DRAM_zio_inout
       DRAM_rzq_inout
       DRAM_dq_inout<0>
       DRAM_dq_inout<1>
       DRAM_dq_inout<2>
       DRAM_dq_inout<3>
       DRAM_dq_inout<4>
       DRAM_dq_inout<5>
       DRAM_dq_inout<6>
       DRAM_dq_inout<7>
       DRAM_dq_inout<8>
       DRAM_dq_inout<9>
       DRAM_dq_inout<10>
       DRAM_dq_inout<11>
       DRAM_dq_inout<12>
       DRAM_dq_inout<13>
       DRAM_dq_inout<14>
       DRAM_dq_inout<15>
   IO Standard 1: Name = SSTL15_II, VREF = NR, VCCO = 1.50, TERM = NONE, DIR =
   OUTPUT, DRIVE_STR = NR
       DRAM_reset_n_out
       DRAM_dm_out
       DRAM_cke_out
       DRAM_a_out<0>
       DRAM_a_out<1>
       DRAM_a_out<2>
       DRAM_a_out<3>
       DRAM_a_out<4>
       DRAM_a_out<5>
       DRAM_a_out<6>
       DRAM_a_out<7>
       DRAM_a_out<8>
       DRAM_a_out<9>
       DRAM_odt_out
       DRAM_udm_out
       DRAM_ba_out<0>
       DRAM_ba_out<1>
       DRAM_ba_out<2>
       DRAM_a_out<10>
       DRAM_a_out<11>
       DRAM_a_out<12>
       DRAM_cas_n_out
       DRAM_we_n_out
       DRAM_ras_n_out
   IO Standard 1: Name = DIFF_SSTL15_II, VREF = NR, VCCO = 1.50, TERM = NONE,
   DIR = OUTPUT, DRIVE_STR = NR
       DRAM_ck_out
       DRAM_ck_n_out
   DIR = BIDIR, DRIVE_STR = NR
       DRAM_dqs_n_inout
       DRAM_udqs_n_inout
       DRAM_dqs_inout
       DRAM_udqs_inout
The IOBs are all using VCCO=1.5, so why they are conflicting?
Furthermore, I would add some LVCMOS15 on the same bank, but these also would be added to the conflicting list...
What is wrong?
Andrea
Re: Spartan6 with DDR3 IOB conflict
I found the problem eventually.
I had added some inout signals expected to work with LVCMOS33. Enabling input termination obviously caused incompatibility with VCCO=1.5V, but the tool didn't notified this problem, so I was looking the cause in the wrong direction.
Andrea
you need to regenerate the IP for DDR3 you cant simple change the UCF here, if you regenerate the IP targeting DDR3 does that show the same behaviour?
Andrea
excellent great to hear you have resolved it
