Spartan6 with GPMC
 Hi, I am trying to configure Spartan 6 FPGA to communicate with AM3358 microprocessor through GPMC bus, 16-bit non-multiplexed for asynchronous single access reads/writes. In order to configure the GPMC properly, I need to know certain timing characteristics of the FPGA. The below pictures are examples from the GPMC datasheet. I looked through the FPGA datasheet but I am unsure how to figure out these timing properties. How do I figure out these timing characteristics?
Scholar drjohnsmith
Re: Spartan6 with GPMC
first you need to decide which method of configuration your going to use for the FPGA,
have look here
https://www.xilinx.com/support/documentation/user_guides/ug380.pdf
I'd assume your going for a slave mode, which are on page 18.
Yes, I'd like the FPGA to slave configuration mode to a Microprocessor.
Edit: Actually after looking at the configurations, I don't want the FPGA to be any of those. I don't think I need to configure FPGA to be in any of those slave configurations. Between microprocessor and FPGA, I just have address lines, data lines, CS, WE, and OE.
Scholar drjohnsmith
Are you trying to configure the fpga ?
   if so, you need to now what mode its going to use.
If you are not needing to program it, can you give us more details as to what you want to do ?
I am trying to use the FPGA as an external device to a GPMC like as shown in the image.
In order to properly configure the GPMC I need to know timing information about the FPGA, but I'm not sure how to figure out these timing characteristics.
Scholar drjohnsmith
Ok,
my apologies,  was assuming you were looking at configuration, which does have timing.
You want to interface to the fpga,
   for that, you need to design the code for the fpga,
      and its your code / system that will define the timing.
Ok so far I have designed the code. But what should I look at to determine the timing? I am really new to any timing analysis.
Thank you for helping.
Scholar drjohnsmith
Ok,
so first up, I'd do a model of the GMPC. in what ever language your using,
      that will include the timing information from the CPU data sheet
Then check does your interface work functionaly.
when you have that, post us the waveforms ,
