Test Bench Error
I am trying to get a test bench up and running and I get these errors i don't understand.  there is no prevent_reg_update
ERROR: [VRFC 10-704] formal prevent_reg_update has no actual or default value [C:/Users/xxxxxx/Documents/control monitor/modified/project_3/project_3.srcs/sources_1/imports/temp/regifile_fsk_test.vhd:26]
ERROR: [XSIM 43-3321] Static elaboration of top level VHDL design unit cm_fpga_10 in library work failed.
Re: Test Bench Error
What does line 26 of regifile_fsk_test.vhd look like?
www.xilinx.com
Prevent_reg_update : in std_logic; -- Allows writing to all registers
Have you tried searching for the error message? A few min on google gives some useful advice.
http://stackoverflow.com/questions/14527201/vhdl-assigning-default-values
"All entity inputs must have either a signal driving them, or a default value specified in the entity declaration."
www.xilinx.com
