The I2C communication stopped working on Nexys A7 FPGA boards
I have Nexys A7 FPGA board. Board boots up. But the I2C communication has stopped working.
I checked voltage using multi-meter between clock pin and ground pin. The clock line (for I2C - "JA") is low.
I also checked the resistance between JA pins and ground. Between clock pin and ground, it is around 700 Ω. Whereas on pins other than clock, the resistance is 2 MΩ.
I measured resistance across resistor R3. The value matches the schematic data of 200 Ω.
Can someone help to make the I2C communication work.
Re: The I2C communication stopped working on Nexys A7 FPGA boards
We figured out that the ESD protection diode D3 connected to this line is damaged.
Jayshree
Hi jayshree,
Maybe I'm missing something, but why do you assume that the PMOD JA can handle I2C? Which PMOD are you connecting to it?
Andres
Are there pull up resistors on your I2C lines?
Hi Andres,
Jayshree
Jayshree
Good job, Jayshree! Thanks for the update!
Mark your answer as an Accepted Solution to benefit other users and to close this thread.
Cheers,
Andres
