The minimum number of clocks to drive 10 PLLs using xc7k410tffg900
Hi.I am using xc7k410tffg900 FPGA. According to the document, xc7k410tffg900 FPGA has 10 PLLs. Now I have to use all 10 PLLs at the same time, I wonder how many clks should I use at least to drive the 10 PLLs.
Scholar drjohnsmith
Re: The minimum number of clocks to drive 10 PLLs using xc7k410tffg900
It depends upon your circuit in the fpga.
You need to do a basic design in the fpga to see what clocks you need to use,
Scholar drjohnsmith
If my pcb has not been designed, what is the minimum number of oscillaters should I place in the pcb?
 How many clk_in should I used to drive all the 10 PLLs in k7 410T FFG900 ?
Scholar drjohnsmith
Suggest you dont add to a closed forum post, as its unlikely to get many looks.
In this case the answer is the same as above,
    do a dumy design,
