UART not woring
I have an AC701 with an unsupported device, which means I don't have a board file and I'm defining IO pins manually.
I have so far failed to get the UART to communicate. Going through the standrad board schematics, I see there are two extra USB ports which I am not defining when using AXI UARTlite: USB_UART_RTS and USB_UART_CTS.
Is this why it is not working? How do I define them?
Re: UART not woring
Hi @simchask,
I don't know what to tell you more. You have an unsupported board... We cannot know what is the pinout...
Florent
Re: UART not woring
I finally got the microblaze to run a program that blinks the GPIO LEDs. So I know that at least some of the XC7A100T pins on the AC701 board match the XC7A200T. S: the differential clock, the CPU reset, and the LEDS.
So why can't I get any love from the UART?
Re: UART not woring
Hi @simchask,
Can you see the UART port as COM port in your machine? Are you using tera term as recommended?
Florent
Re: UART not woring
I can see the UART port. I am now trying with putty. Tera Term was flagged as a virus by my anti-virus.
Re: UART not woring
Still nothing. I am now convinced the pads are different than the AC701 with XC7A200.
I am lost.
Re: UART not woring
Hi @simchask,
Florent
Re: UART not woring
I had exactly the same problem. The reason is... mistakenly swapped RX and TX lines in schematics.
Try to set pins as following:
set_property PACKAGE_PIN T19 [get_ports uart_rx]
set_property PACKAGE_PIN U19 [get_ports uart_tx]
