Newbie applepai
UG480 XADC reset control registers
Currently , I am able to read and write with the XADC without any trouble. I can read the vaux channels and temperature, as well as write to the control registers to change the config.
But after changing the control registers and resetting the device, the control registers aren't reset back to their initial values, but instead retain their configuration from before the reset.
For example, at startup vaux channels 0-5 and 8-12 are enabled. After disabling the channels and resetting the device, they remain disabled.
Is there a way so asserting reset will also reset the control registers?
Andrew
    .INIT_40(16'h9000),
    .INIT_41(16'h21FF),
    .INIT_42(16'h0800),
    .INIT_43(16'h0000),
    .INIT_44(16'h0000),
    .INIT_45(16'h0000),
    .INIT_46(16'h0000),
    .INIT_47(16'h0000),
    .INIT_48(16'h4701),
    .INIT_49(16'h1F3F),
    .INIT_4A(16'h0000),
    .INIT_4B(16'h1F3F),
    .INIT_4C(16'h0000),
    .INIT_4D(16'h0000),
    .INIT_4E(16'h0000),
    .INIT_4F(16'h0000),
    .INIT_50(16'hB5ED),
    .INIT_51(16'h57E4),
    .INIT_52(16'hA147),
    .INIT_53(16'hCA33),
    .INIT_54(16'hA93A),
    .INIT_55(16'h52C6),
    .INIT_56(16'h9555),
    .INIT_57(16'hAE4E),
    .INIT_58(16'h5999),
    .INIT_59(16'h0000),
    .INIT_5A(16'h0000),
    .INIT_5B(16'h0000),
    .INIT_5C(16'h5111),
    .INIT_5D(16'h0000),
    .INIT_5E(16'h0000),
    .INIT_5F(16'h0000),
    .IS_CONVSTCLK_INVERTED(1'b0),
    .IS_DCLK_INVERTED(1'b0),
    .SIM_DEVICE("7SERIES"),
Re: UG480 XADC reset control registers
Applepai,
How are you resetting the SYSMON? When you say you reset the device are you reconfiguring the part? Does the reset behave the way you expect in simulation?
T
