Use of 'No Load' resistors in Arty board schematic
I'm referring the Arty Board schematic. What is the necessity of using some resistors marked as "No Load"  in some pins? Some of them have values 0,100 etc.
Thank you...
Tags (3)
Often the board designer may add resistors in as an option and then decide later to populate it on the board.
So for instance you may need to pull up or pull down a pin depending on the mode so both options are added but only one ends up populated
I suspect this is the case here
