User GPIO KC705 output swing
Hi there,
I'm trying to bring out a couple of user-generated single-ended signals to the user GPIO SMA connectors on a KC705 board. I am setting the pins to LVCMOS18 however I'm only getting ~700mV voltage swing at the output and it looks very capacitive (1.8V is the minimum requirement for my design).
How can I get a square wave with a maximum swing out of the GPIO connectors? attached is the scope capture of the waveforms
Mandana
Community Manager
Community Manager
Re: User GPIO KC705 output swing
Hi @mkhazrai
How are you driving that output? Are you using an OFD or ODDR or the like?
What load do you have on the SMA? If its just the scope what termination are you using on the scope?
Sandy
Sandy
