brechat
VC707 BPI Flash Access using AXI EMC
Hi everybody,
I'm trying to access a BPI Flash memory from a Kintex 7 FPGA (this is the memory where bitstream is stored). The driver keeps stucking on Init and I want to be sure that the problem is not coming from timing. The memory part number is PC28F256P30BFE from Micron (datasheet attached)
I've simulated the output of EMC block and I notice something strange: normally, for a write operation, CE should go low, then WE, and after the write operation, WE goes high and THEN CE goes high. On the simulation I see that CE goes high BEFORE WE. Is this right?
This is the simulation results:
and this is the IP timing configuration
Thanks for your help!
Mariano
pratham
@brechat I would rather suggest you check the design's behavior using ILAs. If you have copied timings from the datasheet then probably it is right.
-Pratham
pratham
-Pratham
brechat
Thanks @pratham. I will try with the ILA
Mariano
