VC707 SoC design
Recently We purchased two Xilinx VC707 evoluation boards from AVNET India.
We tried to generated custom SoC using Ethernet and USB IP's along with some other pheriperals.
Remaing all other pheriperals working fine. But we are not able to generate SoC with Ethernet and USB Host controller.
If any one has working slution for Ehernet and USB host controller fot VC707, please shere relevent MHS and UCF files.
Rajashekar
Manjeera Digital Systems
Re: VC707 SoC design
XTP205 -  VC707 BIST Tutorial ( ver12.0, 48776 KB ) [PDF]
Run, compile, and program the BIST Flash Application for the VC707
Thanks and Regards
Balkrishan
Thanks Balkrishan for quick reply.
We tried these thing.
1. AXI Eternet is working in loop back mode. But not communicating with gateway.
2. We need USB Host application, not USB device. We are trying to add XPS_USB_HOST to have host controller. But no component is detected.
