07-17-2017 11:13 PM
Our VC707 doesn't work.
We use Vivado 2017.1. We can find device and program vc707 via JTAG. But It seems not work.
For example, when programed IBERT series 7, there are no content in 'Serial I/O Links', and no signal output.
and when we restart (power off and on) vc707, LED2 is always on.
and when using BIST test vc707, all test passed except 4. FLASH test.
It says "fail at initialize" .
Could you help us what should we do ?
07-17-2017 11:22 PM
Hi @eunchong
Please run through the https://www.xilinx.com/support/answers/51233.html and let us know the results.
07-17-2017 11:30 PM
@vijayak Interesting
Here
https://www.xilinx.com/support/documentation/boards_and_kits/virtex-7/vc707-bist-pdf-xtp140-14.3.pdf
it says that SW11 should be 11010
07-18-2017 09:06 PM
Hi vijayak,
We followed
and at 6. Master BPI Configuration, using iMPACT, we identified vc707 successfully. But we failed at programming.
log as below;
INFO:iMPACT - Current time: 2017/07/19 12:29:09
// *** BATCH CMD : Program -p 1 -dataWidth 8 -rs1 NONE -rs0 NONE -bpionly -e -v -loadfpga
Maximum TCK operating frequency for this device chain: 66000000.
Validating chain...
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading: 44.96 C, Min. Reading: 43.48 C, Max. Reading: 45.95 C
1: VCCINT Supply: Current Reading: 0.999 V, Min. Reading: 0.996 V, Max. Reading: 1.005 V
1: VCCAUX Supply: Current Reading: 1.811 V, Min. Reading: 1.811 V, Max. Reading: 1.813 V
Core is not loaded.
BPI SLAVE TYPE in Cse_Operate.c is 0
INFO:iMPACT - Downloading C:\Xilinx\14.7\ISE_DS\ISE\data\cse\cseflash\virtex7\xc7vx485t_xsdbbpi_lvcmos18.cor core file.
INFO:iMPACT - Creating XC7VX485T device.
'1': Programming device...
Match_cycle = NoWait.
Match cycle: NoWait
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:Cse - Status register values:
INFO:Cse - 0011 1111 0101 1110 0000 1000 0100 0000
INFO:Cse - '1': Completed downloading bit file to device.
INFO:Cse - '1': Programming completed successfully.
PROGRESS_END - End Operation.
Elapsed time = 2 sec.
key: period_frc, value: 0
key: dclk_has_reset, value: 0
key: period_int, value: 10
Found Slave on Bus Index.
Slave Int Type is 0, Slave Index is -1, BPI_SLAVE is 83
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings.
what should I do next?
07-24-2017 10:27 PM
07-24-2017 10:41 PM
@eunchong Open a service request?
https://www.xilinx.com/serviceportal.html#serviceportal
07-24-2017 10:44 PM
Hi @eunchong
What are your mode pins set to? Please send me the status register information.
Is this board under 90 days warranty? If yes, ask your FAE to file a RMA SR.
If not under warranty, contact whizz systems.
Whizz Systems are our contract manufacturer and official Xilinx Design Partner.
They are best placed to repair Xilinx Development Systems Products (Boards and Kits) at the cost of the customer.
info@whizzsystems.com
http://www.whizzsystems.com/contact-us/
PS: Before contacting Whizz systems, it will be good to confirm that this is the board failure.
07-25-2017 02:19 AM
07-25-2017 06:59 PM
Hi @vijayak
We tried to read Device Status, but read status resister failed. Log is like below:
INFO:iMPACT - Current time: 2017/07/26 10:56:36
// *** BATCH CMD : ReadStatusRegister -p 1 -bpionly
Validating chain...
1: Device Temperature: Current Reading: 44.96 C, Min. Reading: 41.52 C, Max. Reading: 45.95 C
1: VCCINT Supply: Current Reading: 0.999 V, Min. Reading: 0.981 V, Max. Reading: 1.005 V
1: VCCAUX Supply: Current Reading: 1.813 V, Min. Reading: 1.811 V, Max. Reading: 1.816 V
'1': Read Status Register command is not supported for 28F00AG18F.
Elapsed time = 0 sec.
07-25-2017 10:32 PM - edited 07-25-2017 10:59 PM
Hi @eunchong
You have to select the FPGA and then read the status registers.
I see that you are trying with flash device selected.
07-26-2017 08:46 PM
Hello @vijayak
Your right, We are trying to read flash memory's status...
This is FPGA's status, please check it.
INFO:iMPACT - Current time: 2017/07/27 12:42:51
Validating chain...
1: Device Temperature: Current Reading: 39.05 C, Min. Reading: 28.23 C, Max. Reading: 39.55 C
1: VCCINT Supply: Current Reading: 1.002 V, Min. Reading: 0.996 V, Max. Reading: 1.008 V
1: VCCAUX Supply: Current Reading: 1.816 V, Min. Reading: 1.811 V, Max. Reading: 1.819 V
'1': Reading bootsts register contents...
[0] VALID_0 - ERROR OR END OF STARTUP (EOS) DETECTED : 1
[1] FALLBACK_0 - FALLBACK TRIGGERED RECONFIGURATION : 0
[2] IPROG_0 - INTERNAL WARMBOOT (IPROG) TRIGGERED RECONFIGURATION : 0
[3] WTO_ERROR_0 - WATCHDOG TIME OUT ERROR : 0
[4] ID_ERROR_0 - FPGA DEVICE IDCODE ERROR : 0
[5] CRC_ERROR_0 - CYCLIC REDUNDANCY CHECK (CRC) ERROR : 0
[6] WRAP_ERROR_0 - BPI FLASH ADDRESS COUNTER WRAP AROUND ERROR : 0
[7] HMAC_ERROR_0 - HMAC ERROR : 0
[8] VALID_1 - ERROR OR END OF STARTUP (EOS) DETECTED : 0
[9] FALLBACK_1 - FALLBACK TRIGGERED RECONFIGURATION : 0
[10] IPROG_1 - INTERNAL WARMBOOT (IPROG) TRIGGERED RECONFIGURATION : 0
[11] WTO_ERROR_1 - WATCHDOG TIME OUT ERROR : 0
[12] ID_ERROR_1 - FPGA DEVICE IDCODE ERROR : 0
[13] CRC_ERROR_1 - CYCLIC REDUNDANCY CHECK (CRC) ERROR : 0
[14] WRAP_ERROR_1 - BPI FLASH ADDRESS COUNTER WRAP AROUND ERROR : 0
[15] HMAC_ERROR_1 - HMAC ERROR : 0
'1': Reading status register contents...
[0] CRC ERROR : 0
[1] DECRYPTOR ENABLE : 0
[2] PLL LOCK STATUS : 1
[3] DCI MATCH STATUS : 1
[4] END OF STARTUP (EOS) STATUS : 1
[5] GTS_CFG_B STATUS : 1
[6] GWE STATUS : 1
[7] GHIGH STATUS : 1
[8] MODE PIN M[0] : 0
[9] MODE PIN M[1] : 1
[10] MODE PIN M[2] : 0
[11] INIT_B INTERNAL SIGNAL STATUS : 1
[12] INIT_B PIN : 1
[13] DONE INTERNAL SIGNAL STATUS : 1
[14] DONE PIN : 1
[15] IDCODE ERROR : 0
[16] SECURITY ERROR : 0
[17] SYSTEM MONITOR OVER-TEMP ALARM STATUS : 0
[18] CFG STARTUP STATE MACHINE PHASE : 0
[19] CFG STARTUP STATE MACHINE PHASE : 0
[20] CFG STARTUP STATE MACHINE PHASE : 1
[21] RESERVED : 0
[22] RESERVED : 0
[23] RESERVED : 0
[24] RESERVED : 0
[25] CFG BUS WIDTH DETECTION : 0
[26] CFG BUS WIDTH DETECTION : 1
[27] HMAC ERROR : 0
[28] PUDC_B PIN : 0
[29] BAD PACKET ERROR : 0
[30] CFGBVS PIN : 0
[31] RESERVED : 0
08-02-2017 10:07 PM
