Visitor agnesi
VCCO problem
I use artix-7 device, XC7A200T-2SBG484I.
VCCINT = 1.0V, VCCAUX = 1.8V, and VCCO14/16/34/35 = 3.3V, VCCO13/15 = 2.5V.
VCCO13/15 are voltage for LVDS25.
Configuration Mode is Master SPI(x1)
1. The regulator's output for LVDS25 was 2.9V~3.1V.
2. I checked Device's all power pin, configuration pin, PCB Routing But there is no problem.
3. Although I removed the regulator,  the Voltage did not change.
Currently, TMDS33 is used instead of LVDS25.
What can I do to identify the cause?
* I checked powerpin, PUDC, Modepin
* Four sets of circuit boards were assembled on the SMT line and all boards have the same problem.
Visitor agnesi
Re: VCCO problem
There is no other power connection.
Scholar jg_bds
Re: VCCO problem
Remove the A7 from one of the boards and re-check the voltages.
If VCCO13/15 is still higher than 2.5V, there's a short on the PCB between the power rails. If the VCCO13/15 is 2.5V, there's a problem with the A7 footprint.
-Joe G.
