Video crosspoint
Hi everyone,
I need to do a video crosspoint in a FPGA Spartan6, I have 4 video clock inputs (clk0, clk1, clk2 and clk3) and 4 video clock outputs (clko0, clko1, clko2 and clko3), and I have 4 selection inputs (sel0, sel1, sel2 and sel3) one for each video output
The funcionality I would like to have is:
sel0 = 0: clko0 = clk0
sel0 = 1: clko0 = clk1
sel0 = 2: clko0 = clk2
sel0 = 3: clko0 = clk3
sel1 = 0: clko1 = clk0
sel1 = 1: clko1 = clk1
sel1 = 2: clko1 = clk2
sel1 = 3: clko1 = clk3
sel2 = 0: clko2 = clk0
sel2 = 1: clko2 = clk1
sel2 = 2: clko2 = clk2
sel2 = 3: clko2 = clk3
sel3 = 0: clko3 = clk0
sel3 = 1: clko3 = clk1
sel3 = 2: clko3 = clk2
sel3 = 3: clko3 = clk3
I don't know how I can do it with bufgmux, could anyone help me with this issue?
Thank you
Best regards
Jose
whats your programming language ?
whats the video clock frequency, and format ( LVDS , LVCMOS etc ? )
I work with VHDL and my video inputs are 3G/HD/SD-SDI
if I use external deserializers for each input (GS2971) the video clock has a frecuency of 148.5Mhz
If I use Xilinx transceivers the input frecuency is 3Gbps for 1080p60
I don't know the best way to do my solution
Thank you
well,
the code can only work on the parallel data, be that after the on chip PHY on an external PHY,
then its a simple set of case statements to make three MUX's, one for each out put
I can do 4 mux with 4 inputs and 4 outputs each one (all mux with same data inputs)
But I don't know the way I can do 4 mux with 4 clock inputs and four clock outputs, all mux with same clock inputs
I need 3 bufgmux for each clock mux, for 4 clock mux I need 12 bufgmux
Spartan6 has 16 bufgmux but I don't know the way I can connect each bufgmux because there are hw constraints between global clocks pins and bufgmux inputs
Please see attached
Thank you
sorry , missed that
you don't want a mux,
you receive video on serial links ?
   these then get deseralised.
you then launder them to an internal system clock,
when they are all on the same system clock, then you can mux,
and then seralise again,
The 4 video input clocks have different frequency, for example, one clock can be 148.5Mhz (1080p50) and other one 13.5Mhz (SD525)... they don't have the same frequency and they aren't synchronized
I need to do a crosspoint or mux between different video clocks
I think I need to use bufgmux but I don't know the way because I have errors of bufgmux placement when I sinthetize
In this moment I use external deserializer so I have 4 clock pins in my design
I don't know if I can do this with Spartan
Thank you
Ok,
you want to switch clocks ,
   now thats a bit more difficult.
suggest you start a new project, just with the clocks you want, and test where they can be put on the chip,
    sorry can't remember , which Spartan you got ?
I use Spartan 6 SLX100
I have a project only with clocks inputs, clock outputs and inputs of selection but there is no way to sintethize the solution
Are you getting a synthesis error or a placer error?  I think this should be syntesizable.  The limited number of inputs to each clock tile on the S6 may make it impossible to place & route.
I have a placer error when I do 4 clock inputs and 4 clock outputs
I tried a new code and it works when I have four clock inputs and two clock outputs (4:2)
But I don't know the way to add two more output clocks, perhaps I need to use BUFIO2, but I don't know if pins clocks can go to one bufgmux input and to one BUFIO2 input
This code works (4 clock inputs and 2 clock outputs) but I need to add two more clocks
-- mux0
U00: bufgmux port map(o => clk0_01, i0 => clk0, i1 => clk1, s => sel0(0));
U01: bufgmux port map(o => clk0_23, i0 => clk2, i1 => clk3, s => sel0(0));
U02: bufgmux port map(o => clk0sel_i, i0 => clk0_01, i1 => clk0_23, s => sel0(1));
-- mux1
U03: bufgmux port map(o => clk1_01, i0 => clk1, i1 => clk0, s => sel1(0));
U04: bufgmux port map(o => clk1_23, i0 => clk3, i1 => clk2, s => sel1(0));
U05: bufgmux port map(o => clk1sel_i, i0 => clk1_01, i1 => clk1_23, s => sel1(1));
-- out
U06: ODDR2 port map(clk0sel, clk0sel_i, not clk0sel_i, '1', '1', '0', '0', '0');
U07: ODDR2 port map(clk1sel, clk1sel_i, not clk1sel_i, '1', '1', '0', '0', '0');
I did the 4x4 crosspoint at the end, I need to use 12 bufgmux and 4 bufio2
With that configuration the issue is that I can't add more clocks to do other things, Spartan6 only has 16 bufgmux
Thank you to everybody
