Observer bgiesing
Virtex-5 LUTRAM as shift register even when -shreg_extract is disabled
Hello -
In ISE 13.2 with SIRF overlay targeting xqr5vfx130-1-cf1752, I have disabled shreg_extract to prevent shift registers from being extracted.  However, in the map report, it still states that my design is using 385 LUTRAMs.  I do not see any RAMs, ROMs, or SRL type primitives being reported, so I can only assume LUTRAM is being used as a shift register (but not actual SRL primitive).  When I refer to the XST synthesis report In the are of the design using LUTRAM as indicated by the map report, all synthesis messages are that flip-flops are being inferred.  There are HDL ADVISOR messages in the synthesis report stating flip-flops are inferred for what looks like a RAM, but I do want flip-flops.  What I don't want is LUTRAM shifters being used.  Am I misunderstanding these messages?
Thank you,
Brian
Observer bgiesing
Re: Virtex-5 LUTRAM as shift register even when -shreg_extract is disabled
Looks like we found it.... don't set -global_opt = Speed in Map Properties.  With that enabled, the LUTRAMs show up even though we have their use disabled.  When -global_opt=OFF, no LUTRAMs appear.
Seems as though the tool will make decisions contrary to your direction when you set the -global_opt property.
Scholar jmcclusk
The LUTRAM's may be distributed memory, not shift registers... that's the most common application, actually.
Observer bgiesing
Hello -
Some further information... after inspection of the routed design in FPGA editor, I do indeed see SLICEM resources being used, and within those SLICEM resources I can see they are configured as SRL16 primitives.  In addition to the global -shreg_extract being disabled, I also added synthesis attributes to the signals, but the LUTRAM is still inferred.
Brian
Scholar jmcclusk
If the tool is ignoring your attributes and synthesis flags,   you can probably stop the SRL inference by adding an asynchronous reset to the registers comprising the SRL16..     That is known to prevent SRL inference.
Observer bgiesing
Thanks for the response, but that has already been done. Here is the VHDL snippet:
type tlm_reg_values_array is array(11 downto 0) of std_logic_vector(31 downto 0);
type smp_dly_values_array is array(8 downto 0) of tlm_reg_values_array;
signal smp_dly: smp_dly_values_array;
attribute shreg_extract : string;
attribute shreg_extract of smp_dly : signal is "no";
-- Create the delay lines
smp_dly_regs: process(clk, rst_n)
begin
  if (rst_n = '0') then
    for i in 0 to 8 loop
        for j in 0 to 11 loop
            smp_dly(i)(j) <= (others => '0');
        end loop;
    end loop;
  elsif rising_edge(clk) then
      if (data_addr="11111" and latch_data_d1='1') then
        if pass = X"0" then
            for i in 0 to 3 loop
                smp_dly(0)(i) <= smp_reg(i);
            end loop;
            for i in 1 to 8 loop
                for j in 0 to 3 loop
                    smp_dly(i)(j) <= smp_dly(i-1)(j);
                end loop;
            end loop;
        elsif pass = X"1" then
            for i in 4 to 7 loop
            end loop;
                for j in 4 to 7 loop
                end loop;
            end loop;
        elsif pass = X"2" then
            for i in 8 to 11 loop
            end loop;
                for j in 8 to 11 loop
                end loop;
             end loop;
        end if;
    end if;
  end if;
end process;
Thank you,
Brian
Observer bgiesing
