Visitor kimmoj
Virtex 5: using IODELAY with ISERDES and monitoring
Device: Virtex-5
I would like to use the output of IODELAY instance for internal logic (monitoring etc..)  and ISERDES instance at the same time.
Is this routing scheme allowed ?
Kimmo
Visitor kimmoj
Re: Virtex 5: using IODELAY with ISERDES and monitoring
Hi Pthakare,
Thanks for your reply.
Data rate: 320 Mbps
I tried to use the following schemes shown in the figure below. The version #3 seems to be working.
Kimmo
Hi @kimmoj
The Delayed data (Data_out)  Destination from the IDELAY can be  ILogic/ISERDES/Fabric .
But I am not sure and I would like to check at my end if data_out from the IDELAY can be used in fabric as well as routed to ISERDES.
Meanwhile can you also try and let us know your observations ?
Also what is the data rate incoming data signal ?
For the reliable registering  of data in the fabric , you also need to consider the maximum Supported frequency
in the Virtex-5 fabric.
Reply if you have any queries, Give Kudos and Accepted as solution
Visitor kimmoj
Hi Pthakare,
Data rate: 320 Mbps
Kimmo
