Virtex-7, 330t - How to find the silicon version
Both impact and Vivado LabTools allows to read the ID code of the device.
How to decode this to know the silicon version of the device on board?
Re: Virtex-7, 330t - How to find the silicon version
Check page14 of below doc
http://www.xilinx.com/support/documentation/user_guides/ug470_7Series_Config.pdf
Satish
Please check below link
http://www.xilinx.com/support/answers/37579.html
Hope this helps
-Vanitha
@vsrunga
The V7330T is not there in 7-Series Errata.
Here is the iMPACT capture - can you tell me what silicon version I have.
INFO:iMPACT - Current time: 4/14/2015 12:47:19 PM
Maximum TCK operating frequency for this device chain: 66000000.
Validating chain...
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading:   28.23 C, Min. Reading:   27.24 C, Max. Reading:   28.72 C
1: VCCINT Supply: Current Reading:   0.943 V, Min. Reading:   0.940 V, Max. Reading:   0.943 V
1: VCCAUX Supply: Current Reading:   1.787 V, Min. Reading:   1.784 V, Max. Reading:   1.790 V
'1': IDCODE is '00000011011001100111000010010011'
'1': IDCODE is '03667093' (in hex).
'1': : Manufacturer's ID = Xilinx xc7vx330t, Version : 0
Satish
Production IDCODE Revision --- 0 or later
This means I have production Silicon.
