x1991
Virtex 7 GTX Transceivers
I have a problem with my GTX Transceiver on virtex 7. I use the example design of the ipcore. When i test the design in
chipscope it works fine but sometimes the receiver resets themselves. I don't know why??
venkata
How is track_data_out signal is behaving?
yenigal
Does the clocks and reset inputs to the core clean and stable?
Can you attach the captures showing the issue.
Satish
umamahe
Also please scope the MGTpower supplies continuously for sime time during testing . There could be some supply noise.
