[Vivado 12-1411]
Vivado
I use the kc705 to instantiate a 7 series Transceiver IP  , when i implement ,it has  two critical warnings ,as follows...
[Vivado 12-1411] Cannot set LOC property of ports, Terminal Q2_CLK1_GTREFCLK_PAD_N_IN has conflicting location from shape expansion (ILOGIC_X0Y174 FIXED, ILOGICE2.D2OBYP_SRC) vs original (IOB_X0Y173 FIXED, IOB33S.PAD)
however ,they are the same ...
what's the meaning of it???
In my XDC file ,i have this commend...
set_property LOC K29 [get_ports Q2_CLK1_GTREFCLK_PAD_N_IN ]
set_property LOC K28 [get_ports Q2_CLK1_GTREFCLK_PAD_P_IN ]
  K28,K29   is the pin of 156.25MHz.....
Meanwhile,this warning affect the bit file's generation ......
who can help me ???
thanks!!!
The user clocks generated by si570 cannot be used for the SFP+ transceiver,this clock is for FPGA logic.
Transceivers have dedicated clock pins and for KC705 the SFP+ is connected to QUAD117 and the reference clocks can be provided from the SMA connector or the SGMII clock.
The clock reference pins are G8 and G7.
Refer SGMII GTX transceiver clock generator section of UG810 to know more about this.
Also the pinout in the below link will give you clarity on the clock pins.
http://www.xilinx.com/support/packagefiles/k7packages/xc7k325tffg900pkg.txt
Satish
Can you open synthesized design and check how this port is connected in schematic "Q2_CLK1_GTREFCLK_PAD_N_IN "?
From the naming this looks like to be a GTREFCLK pin. If this is the case you need to lock them to the GT dedicated pins.
K28 and K29 are not GT dedicated pins.
For more details refer to APPENDIX-A of http://www.xilinx.com/support/documentation/user_guides/ug476_7Series_Transceivers.pdf
Deepika.
Deepika.
i want to connect  the gtx Ip with the SFP+ ,the reference clock is 156.25. Two way i can get this clock. In the KC705 board ,there is SMA interface which provides the clk ...another way ,through Si570 3.3V LVDS I2C Programmable Oscillator ,i can get this clk, K28 and K29  are the pin ....
thanks ...
Satish
Thank u very much...
You can use 156.25 MHz reference clock from Si570 oscillator for SFP+ via K28 and K29 pins on KC705.
I had simillar problem with Ten Gigabit Ethernet PCS/PMA (10GBASE-R/KR) and exactly same conflict messages.
I regenerated the core with "Include Shared Logic in example design" setting.
In generated IP Example Design I modified file with input clock buffers to use generic IBUFDS instead of IBUFDS_GTE2
Then I instantiated one of example HDL wrappers together with the generated core.
And now it works !
