Vivado 2019.2 parameters for two different IPs with same name causing conflict
I am working on a project where we have two IPs with the same parameter names used in the IP files. Since some of the parameters are defined for one IP and the same named parameters are undefined for the second IP, we are facing issues with Vivado synthesis flow. Other than renaming these parameters with unique names, is there any option in Vivado to restrict specific parameters to specific files and then combine all these modules together in the same netlist ?
Best Regards,
Sumi
