acgropp1
What does the RXCDR_CFG do exactly?
Hello, I am trying to thoroughly understand how the CDR unit works in the GTX.  I have not be successful in finding much information in it. I did notice that there is a RXCDR_CFG parameter that is generated by the GT wizard. The GTX user guide specifies to use the generated value. What exactly does this configure in the CDR? Thanks in advance.
Adam Gropp
acgropp1
By the way I am using the KC705 eval board
balkris
check this AR
http://www.xilinx.com/support/answers/57742.html
Thanks and Regards
Balkrishan
acgropp1
Thank you for this. So is it a parameter for the edge sampler (ppm) and data sampler (protocol)? I am just wanting to understand it at a lower level.
venkata
The details of the parameter is not shared in any external documentation. The recommendation is to use the value generated from GT wizard.
venkata
RXCDR_CFG sets the CDR parameters like loop bandwidth, enabling first order/second order loop, allowed ppm level etc.
