What protocol it's more easy to use..I2C or SPI in verilog?
Hello, I'm new with the HDL with verilog and I want to know what it's the protocol more easy to use to conect a lcd screen on Nexys4 DDR XC7A100T-1CSG324C... the I2C protocol or SPI protocol and there are an example of the code.
thx
Tags (4)
Hi @jpsuarezq,
Digilent is nice in that they put examples using most of the on board devices on their site:
https://store.digilentinc.com/nexys-4-artix-7-fpga-trainer-board-limited-time-see-nexys4-ddr/
It looks like they have RTL for the RAM module:
https://github.com/Digilent/Nexys-A7-100T-OOB/blob/de23e9111bfef268624559537002bc33d6cca009/src/hdl/Ram2Ddr.vhd
Which is where I would start.
As for SPI vs I2C, I generally find SPI a bit easier to code up. But there are a lot fo good examples floating on Github so neither should be limiting.
