ackye
When I configure the 7 series FPGA IO as DIFF_HSTL_II_F_18 to receive the SUBLVDS signal, do I need to add an additional 100 ohm termination resistor on the board?
sandrao
Community Manager
Community Manager
Hi @ackye
I would suggest trying to go an IBIS simulation of your setup and following the suggestions in the SelectIO UG to ensure the correct thresholds are seen at the device.
https://www.xilinx.com/support/documentation/user_guides/ug471_7Series_SelectIO.pdf
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
