hokim
When is ALMOSTEMPTY of FIFO36E1 signal active?
I use FIFO36E1 in which FIRST_WORD_FALL_THROUGH is TRUE.
If ALMOST_EMPTY_OFFSET is 15, is ALMOSTEMPTY signal active when the number of data words remained in fifo including current dout  is 15 or 16?
Thanks in advance
hokim
My simulation result is 14. Is there anything wrong in my code?
rdata= 495, rden = 1, empty = 0
rdata= 496, rden = 1, empty = 0
rdata= 497, rden = 1, empty = 0
rdata= 498, rden = 1, empty = 0
rdata= 499, rden = 1, empty = 0
rdata= 500, rden = 1, empty = 1
rdata= 501, rden = 1, empty = 1
rdata= 502, rden = 1, empty = 1
rdata= 503, rden = 1, empty = 1
rdata= 504, rden = 1, empty = 1
rdata= 505, rden = 1, empty = 1
rdata= 506, rden = 1, empty = 1
rdata= 507, rden = 1, empty = 1
rdata= 508, rden = 1, empty = 1
rdata= 509, rden = 1, empty = 1
rdata= 510, rden = 1, empty = 1
rdata= 511, rden = 1, empty = 1
rdata= 512, rden = 1, empty = 1
rdata= 513, rden = 1, empty = 1
vemulad
Hi @hokim
If ALMOST_EMPTY_OFFSET is 15, then the ALMOST_EMPTY flag will get asserted when the number of words left in FIFO is 15.
Deepika.
hokim
Thanks for your reply,
My point is that the words left in FIFO include or not current DO in FWFT(FIRST_WORD_FALL_THROUGH) mode.
At first, I thought the words left in FIFO of FWFT includes DO.
So I thought the following code has wrong ALMOST_EMPTY_OFFSET and it shoul be 'h10 not 'hf
 https://github.com/pavel-demin/red-pitaya-notes/blob/master/cores/ axis_ram_writer_v1_0/axis_ram_writer.v
But the code works well on fpga. So I guess  FWFT doesn't include DO.
